tired 351
Old Sep 29, 2004 | 11:36 PM
bigblocksix's Avatar
bigblocksix
tired 351
my 351w in my truck is gettin prety tired, down on power, burns oil, oil pressure builds slowly in the morning, its got 300 000 km on it (canada) still runs good though. im thinkin of rebulding it this winter, would i be able to get away with a ring and hone, new bearings, new oil pump, turn the crank, cam lifters and timing set, and have the heads done? would it be fine just to ring and hone? or would i be crazy to do that much work and not bore it
Old Sep 30, 2004 | 07:55 AM
jwtaylor's Avatar
jwtaylor
Whether you could simply hone and install new rings and get away with only installing new bearings is something you can only know when you get there. Good luck
