Has anyone heard of this company or is anyone using this on thier 6.0 psd? Its like the banks because it plugs in under the hood. Its called " Ford Power Enforcer" the gains are to an additional 175Hp and 350Ft.-lbs of Torque at the flywheel. Also they have a programmer the " Xcelerator LB7" for the duramax with additional 300HP and 600Ft.-lbs of Torque max at the flywheel for the 2001 and 2004 models I wish they would make this for the 6.0 psd.
Don't believe the hype... stock injectors cannot deliver that kind of horsepower and anyone claiming a programmer or fuel box alone will do it is fudging their numbers...
well sir no disrespect,but on the duramax it is very attainable.only need a lift pump and an aftermarket tranny to hold it.look up tts extreme power loader
they say all kinds of stuff, man but when it comes down to it, if u want that kinda power, u will have to go big on the injectors.
u might get the stockers to squeeze that kinda fuel for a little bit but not for long
and the boost it takes to burn 300hp worth of fuel will not be tolerated by stock parts for long either.
Well sir no disrespect you didn't read what I said: "anyone claiming a programmer or fuel box alone will do..."
How is a lift pump and aftermarket tranny "a programmer or fuel box" alone?
the duramax will make the power with bone stock injectors.it does need a lift pump to help the high presure pump keep up but it will make the power all by itself with out the lift pump its is just bad on the pump.as far as the teranny goes that is just to put the power to the ground.i have a duramax with a tts extreme program and it dynoes over 525hp and over 1100 lbs of tq with just the program.add some lp and nos and well its much better.pehaps some of you made it to commerce ga for the recent diesel drags,that was my duramax turning 11s in the 1/4
Alone is alone, it doesn't mean with mods X, Y and Z to accomodate the changes. Your explaination is like the guys who claim they do so great with a stock Lightning only to later find out they changed the lower boost pulley and have a Diablo tune.... I don't understand what part of alone isn't clear?
ok to answer your responce and hopefully end it all take my rear wheel hp numbers and add 20 percent for drive line lose to it and it is well over 300hp and 600 lbs and the flywheel like the original post was about anyhow.hopefully this is over but i wait to see,
Curious do you own a Ford truck...or what do you own.
