the duramax will make the power with bone stock injectors.it does need a lift pump to help the high presure pump keep up but it will make the power all by itself with out the lift pump its is just bad on the pump.as far as the teranny goes that is just to put the power to the ground.i have a duramax with a tts extreme program and it dynoes over 525hp and over 1100 lbs of tq with just the program.add some lp and nos and well its much better.pehaps some of you made it to commerce ga for the recent diesel drags,that was my duramax turning 11s in the 1/4
I was there either three or four weeks ago for the Diesel run; The performance Cummins was there. I remember a Duramax making a pretty good run...were you there that weekend? What color is your truck?
i have a pewter 03 duramax ,i ran low 12s and a few 11s with the dmax and was told not to run anymore because of no rollcage,i also have a white F250 psd ,an 04 that ran low 13s at that event.it was at the mopar versus the world event
I was there for the Mopar event also; my stepdad had a 440 67 GTX at the show. I probably saw you run; I was there with my stepdad and also helping my friend and her dad; He runs a 1/8th mile bracket car.
I didn't stay that long; I left with my friend. It was a pleasant day earlier on but started getting excessively hot when the breeze died off at about 3 oclock.
lots of supernice cars at the show and yes it got so hot i gave up cold beer for cold water.did either of you happen to check out that concept car from chrysler,said it was like 0-60 in 2.9 and run the 1/4 in the 10s i think,truly amazing
Yeah, what was it? Like 850 Hp to the wheels or something crazy? It was an awesome looking car. The jet cars were pretty cool too.
I know a D-Max that is just extreme....and it does haul.
Problem is it setting in the corner of his shop right now and will not run at all. Injectors and tranny are toast.
