Sponsored by: Auxito
A/C Noise!! Any Help??
Old Sep 29, 2004 | 03:58 PM
bbyers's Avatar
bbyers
I have noticed a "gurggling" sounds coming from my A/C.
Seems to do it more at idle than at speed. And it seems to do it more right after I sart it up. When I turn the A/C off it quits. Does not appear to be the fan. Could the refrigerant be low?
Old Sep 29, 2004 | 08:57 PM
LxMan1's Avatar
LxMan1
Check the coolant level first. It could be the heater core and it's low on antifreeze.
It could be low on freon too. Usually it will cycle on and off if the pressure switch is working properly.
