Sponsored by: Innova
Blown Sub
Old Sep 29, 2004 | 03:51 PM
Eagl986's Avatar
Eagl986
Blown Sub
I've got a '97 Mountaineer with the JBL Premium sound system. About a month and a half ago, I was listening to a CD on the way to school, and after a while realized that the bass wasn't working. When I turned it back on after school, it worked for 5 seconds, then stopped, and hasn't worked since. Any ideas as to why this happened? I've already checked fuses, and everything was fine there.
Also, do most head units work with the 6-disc changer that comes with the 97 explorer/mountaineer?
Old Oct 2, 2004 | 12:33 PM
Eagl986's Avatar
Eagl986
Anyone????
Old Oct 2, 2004 | 10:42 PM
MemOrex's Avatar
MemOrex
It could be the amp that messed up. Maybe some wiring came loose. Have you installed any aftermarket headunits recently?
Old Oct 2, 2004 | 11:03 PM
Eagl986's Avatar
Eagl986
Nope. I haven't done anything to it.
Old Oct 2, 2004 | 11:33 PM
MemOrex's Avatar
MemOrex
Does the amp have any fuses? If so, are they good?
Old Oct 4, 2004 | 09:54 AM
Fordranger1990's Avatar
Fordranger1990
you could have a loose connection to the remote wire on the back of head unit. It is a blue wire and if it looses connection your amp won't work all you have to do is pop out the head unit and make sure it is connected properly. Most likely will be only blue wire.
Old Oct 4, 2004 | 04:14 PM
MemOrex's Avatar
MemOrex
Try plugin any speaker where the Sub is to make sure that its getting power
Old Oct 10, 2004 | 12:40 PM
Eagl986's Avatar
Eagl986
It turns out it was the speaker, not the amp or headunit that was the problem. I'll just go out and get another 6.5" this week.
