transmission types ???
are what 5 speeds will because i really want a 5 speed tanx for the help
what do yall think a 5 speed will do for my inline 6 i got a 3 speed with od
ZF from small block and six equipped later models.
Keep in mind you need to convert to juice clutch.
T-5 may be a bolt in, I'm going to try one I think. T-5 does not have a super low 1st, and is not up to heavy towing or loads. (I figure they put them behind 300 hp motors, so if I'm careful....) T-5 will probably use your existing clutch.
ZF has low first gear. Not sure how the gears compare to yours.
I have the same tranny, 4 speed, 4th is over. 2nd to 3rd is the grand canyon. ZF may have the same issue 3rd to 4th, not sure.
