code 34
Old Sep 28, 2004 | 08:13 AM
oldbird1965's Avatar
oldbird1965
code 34
I can't seem to find anything on code 34. Its 'EVP sensor voltage above closed limit'. I've got that code on both KOEO & KOER. Should I replace the vapor canister? Thanks
Old Sep 28, 2004 | 08:25 AM
EPNCSU2006's Avatar
EPNCSU2006
I would test the EVP (EGR valve position sensor) to see what the voltage is. If you have a Haynes manual, the test procedure is in there. The code could be caused by a faulty EVP, faulty wiring, a stuck open EGR valve, or a vacuum leak through the EVR solonoid.
Old Sep 28, 2004 | 10:20 PM
oldbird1965
code 43
Thanks for the reply. I should have included the following information. Its a 91 F150 351W and I've replaced the egr & egr sensor. I had some egr codes but not anymore. Just this EVP code 34. I'll do some more testing and get back.
