1997 f250hd 7.5 running rich
Old 12-06-2014, 10:12 AM
brodie429's Avatar
brodie429
brodie429 is offline
I have a 97 f250hd with a 7.5 that is running rich ,new o2 sensor , no vaccum leaks . Any help would be appreciated
Old 12-06-2014, 08:46 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,164 Likes on 919 Posts
How do you know it's running rich?
Old 12-06-2014, 10:04 PM
craftsmangary's Avatar
craftsmangary
craftsmangary is offline
What codes does it have? Is that truck OBD I or OBD II? could be either in that year. One possibilty is a stuck fuel pressure regulator, so check fuel pressure.
Old 12-07-2014, 12:37 PM
brodie429's Avatar
brodie429
You can smell it's running rich. It is an obd 1 system . had it hooked up to a snap on scanner and it is showing that the egr isn't opening also , checked the fuel pressure and it's good . there is no vaccum at the egr but there is at the solenoid. also replaced the coolant temp sensor going to try replacing the intake air sensor
Old 12-07-2014, 01:29 PM
craftsmangary
EGR really doesn't have anything to do with running rich. What codes did you get with the scanner? What are the fuel trim numbers?
Old 12-07-2014, 02:48 PM
brodie429's Avatar
brodie429
the codes were 171,173,332,334 . don't know the fuel trim numbers off hand , heading to the garage now to work on it . I will take the laptop with me and post the numbers , Thanks
Old 12-07-2014, 03:45 PM
rla2005's Avatar
rla2005
Did you remove the vacuum line at the Fuel Pressure Regulator to inspect it for signs of fuel by sight or smell? A ruptured FPR diaphragm is very common.
Why blindly replace sensors if there is no code for them?
Old 12-07-2014, 03:46 PM
rla2005's Avatar
rla2005
Measure the EVP sensor output with a meter with the engine off, key on. Do the same with the engine running. Apply vacuum to the EGR, verify the EVP signal increases.
EVP= EGR Valve Position sensor, it sits on top of the EGR valve.
Old 12-07-2014, 03:49 PM
craftsmangary
Check the evap solenoid see if its stuck open, that will cause a vacuum leak.
Old 12-07-2014, 04:09 PM
rla2005's Avatar
rla2005
Are you referring to the Canister Purge (CANP) solenoid? If so, your theory is wrong. When that solenoid opens it routes the gas fumes to the input side of the throttle body.
Perhaps you meant EGR Valve Regulator (EVR)?
For reference: Fuel Injection Technical Library » EGR Vacuum Regulator (EVR)
Old 12-07-2014, 07:31 PM
craftsmangary
No, That not what I'm talking about.
This is
Amazon.com: Motorcraft CX1100 Vapor Canister Purge Solenoid: Automotive Amazon.com: Motorcraft CX1100 Vapor Canister Purge Solenoid: Automotive
When it fails in the open position you have a 1/4 vacuum leak
Old 12-07-2014, 08:02 PM
rla2005's Avatar
rla2005
This is
Video Link: http://www.amazon.com/Motorcraft-CX1100-Vapor-Canister-Solenoid/dp/B000C5HGFA
I disagree. The CANP routes the fuel tank vapors to the atmosphere side of the throttlebody.
Old 12-07-2014, 08:41 PM
craftsmangary
That CX1100 connects to manifold vacuum, when it's open at a idle you have a vacuum leak, the O2's go lean, fuel trim is off. I'm pretty sure it's meant to open only at cruise. I had a Ranger a couple weeks ago that the fuel trims were way off, poor idle, at a idle that solenoid was open, the new one isn't, that fixed it.
That solenoid is used on most Fords from the mid 80's to about 97, probably all OBD1 vehicles.
Old 12-07-2014, 09:11 PM
rla2005's Avatar
rla2005
I am more familiar with the 5.0/5.8L engines the CANP is connected to the throttlebody. I will check my manuals to see how the 7.5L is plumbed.
Old 12-07-2014, 09:26 PM
craftsmangary
I just looked in Mitchell, 5.0, 5.8, and 7.5 49-States are all plumbed the same way, looks like the same diagram, you better look at it.
Quick Reply: 1997 f250hd 7.5 running rich
