My beloved wife accidently inserted a cd into the cd player with a cd already in the player. Now I have two cds in the player and it is jammed. How can I remedy this problem without a divorce?
2004 explorer? If you take it back to the dealer, I'm sure they can get it out! I myself have gotten them out! you need to rmove the unit from the dash and remove the top cover and very carefully guided the top cd back out the slot. don't worry about the other one. after removing the one replace cover and put unit back in dash good luck
You sure you're not married to my wife? She did the same thing. I just took a pair of small tweezers and pull them out. You can also try to use 2 credit cards and sorta use them like tweezers..that's worked for me also.
That is of course, if they are visible from the front like mine were.
