'01 SOHC Runs Lean
Old Sep 28, 2004 | 09:43 AM
Redbob's Avatar
Redbob
'01 SOHC Runs Lean
I posted about a month ago my problems with the check engine light on, and the fault codes that were set said it was running lean - both cylinder banks.
After MUCH work - changing manifold gaskets, etc. - I got a smoke test done to find the source of the leak, and it was the EGR valve gasket!
All is fine now, and I thought others might be interested in this issue.
Best regards,
Robert
Old Sep 28, 2004 | 11:49 AM
CobraXP's Avatar
CobraXP
Good to know you got it fixed Redbob. I have found personally - and seen it on the boards - that the EGR system on both the 4.0's and the 5.0's can be the cause of numerous codes.
