Fouling Injector?
Old Sep 27, 2004 | 05:20 PM
jonesboys's Avatar
jonesboys
Wink Fouling Injector?
My Truck Always Smokes When I Start It. Not Full Smoke Either. It Is After A Few Pistons Hit Then I Get A Puff Of Smoke. It Is A Deisel. Is It A Fuel Injector Or What?
Old Oct 6, 2004 | 11:35 PM
rangerfun's Avatar
rangerfun
maybe a ring
had same problem, not a ford engine though. Turned out it was a broken ring. The color of the smoke was blue. Compression test showed low compression. squirted some oil into the cylinder and compression came right up. This indicated a broken ring. Turned out one piston had a broken ring land and the other piston had a stuck ring. Worth a try.
VQT
Nov 20, 2013 10:18 PM
Regulator1988
Jan 8, 2013 05:30 PM
whitesdford
Jul 14, 2010 02:13 PM
qtrmile
May 19, 2007 08:16 PM
