1978 - 1996 Big Bronco
Check engine light...
Old Sep 27, 2004 | 04:47 PM
rbachmann's Avatar
rbachmann
Quick question....Have a 90 FSB with a 302 and an automatic trans, the check engine light seems to come on intermitently prior to the truck warming up. The length of time that it's on also seems to vary, and can be anywhere from 3 secs to no more than about 2 mins. This has happened both in and out of gear, but again, only prior to the truck warming up. Any ideas, and should I be overly concerned about this???
Old Sep 27, 2004 | 04:51 PM
F150'89's Avatar
F150'89
Go to your local parts store and buy a FORD code reader for around $30 Some Autozone's can read the codes if you get someone that knows how. The CEL may be due to a lazy O2 sensor or some other sensor that is going bad.
Old Sep 27, 2004 | 05:14 PM
Kemicalburns's Avatar
Kemicalburns
your haynes manual shows you how to pull codes with a paperclip for free. you dont need the code reader
