Dana 60 spindles
Old Sep 27, 2004 | 04:26 PM
minutofgroundhog's Avatar
minutofgroundhog
Smile Dana 60 spindles
I have a 92 F350 4x4 with a dana 60 monobeam front axle. I have been trying to remove the spindles via 3lb hammer and block O' wood. no-joy. Any better ideas out there ?
Old Sep 27, 2004 | 05:06 PM
taz10170's Avatar
taz10170
I just went through this changing ball joints and found that the rubber or
plastic mallet didn't work well. Try a 3 arm gear puller it worked great on my spindles.
Old Sep 27, 2004 | 07:37 PM
minutofgroundhog
Thanks for the reply, I finally did get one side off before nightfall. My axle has nothing to pull on. I did have a 2 arm puller on the jam nut to provide a little preload. The hammer method did work, but I needed a 5lb and some pressure treated pine. Anti- sieze is a definate item on the rebuild.
