i need a little help
Old Sep 27, 2004 | 01:55 PM
tat2d1's Avatar
tat2d1
Question i need a little help
I have a F250 powerstroke turbo 7.3L that has decided not to run for me.
it will start and run for a little bit and then its like its not getting enough fuel because it will chug out and die then it doesnt want to start for me. i was just wondering if any one had any ideas what it could be?
tat2d1
Old Sep 27, 2004 | 02:03 PM
CLK's Avatar
CLK
Could be a few different things, clogged fuel filter, bad fuel pump, faults CAMP (cam shaft position sensor), Check your fuel filter, test to see if you are getting fuel pressure (45-65 psi), more than likely it could be a bay CAMP sensor. This is just my initial diagnosis without further vehicle information.
Old Sep 27, 2004 | 02:25 PM
tat2d1's Avatar
tat2d1
i changed fuel filter and it still doesnt want to go. could the batteries have anything to do with it? some one else told me to go that way and to be perfectly honest i have no idea what i should do and your the second person who told me about the cam shaft sensor...
Old Sep 27, 2004 | 02:38 PM
basstardo's Avatar
basstardo
I'll second the CAMP sensor. Do a search on here and find the International part number. You can get it cheaper from them and do it yourself.
Old Sep 27, 2004 | 03:00 PM
CLK's Avatar
CLK
If your batteries are strong enough to turn the engine over and it did run for a little bit then I doubt they are the problem. Best place as basstardo said get a CAMP sensor form the International dealer, worst case if it isn't you will have a spare, but it will more thant likely be your fix.
Old Sep 27, 2004 | 03:19 PM
tat2d1's Avatar
tat2d1
thanks for the info my last question to you would be is it hard to chg out or is it something easy--the only reason i ask is we are very limited where im at and i was just curious where is is located so i have an idea of what im getting myself into--
thanks again
Old Sep 27, 2004 | 03:31 PM
basstardo's Avatar
basstardo
I've never had to change mine, but from what I've read on here, it's very easy. There's actually an article under the Tech Articles secton about doing it...here's the link:
https://www.ford-trucks.com/article/...ke_Diesel.html
Has all the info you need.
Old Sep 27, 2004 | 03:45 PM
tat2d1's Avatar
tat2d1
thank you very much for the help
Old Sep 27, 2004 | 03:52 PM
basstardo's Avatar
basstardo
No problem...good luck!
Old Sep 27, 2004 | 05:29 PM
tat2d1's Avatar
tat2d1
and if its not the CAMP what would be the next step i should take--like i said ive already changed the filter so then should i go after the fuel pump?
Old Sep 27, 2004 | 11:35 PM
Kwikkordead's Avatar
Kwikkordead
ICP sensor is my thought.
Old Sep 27, 2004 | 11:50 PM
psdpower's Avatar
psdpower
Are you getting a check engine light? If you know someone who has a code scanner that might help.
Old Sep 28, 2004 | 07:09 AM
CLK's Avatar
CLK
you can check the fuel pressure and make sure it isn't a fuel pump, it is easier and cheaper. If you connect a pressure gage (100psi gage) to our fuel bowl drain line and open the the little yellow handle, just turn the key on you shouldn't need to start it, you should have around 60-65 psi, (spec book says as low as 45 psi)
