302FI to carb, will it work?
Putting on a carb is more work than you think... you'd need to change the fueling system and remove the EFI pump in the tank, because if its not working right, its essentially a large cork in your fuel system. Using a low pressure pump whether mechanical or electric in series with a dead EFI pump isn't going to give you enough fuel to adjust your carb properly for consistant operation in the winter. I've been down this road before and it was rather unpleasant (mustang, not a F-series).
How bad does the EFI run? Does the truck run at all? Depending what is hacked up wiring wise, it might be easier to acquire an EFI harness out of a junkyard from the ECM forward. Take you an hour or two to yank it out, another two to slap it on, that might be all you need. Again, that depends as to exactly what is wrong with the truck. Sometimes poor performance is a bad sensor or two, sometimes the injectors are clogged, sometimes the fuel pumps (in tank) are marginal, etc.
If you want to convert to carb, check this article. The site gets shut down during high bandwidth, just try it at a later time.
http://www.jason.fletcher.net/tech/e...b/efi-carb.htm
There are only 3 major components of EFI
1. Actuators and Sensors
2. Wiring harness and Connectors
3. Computer
The computer rarely fails, despite what shade-tree mechanics will tell you. A big source of problems is just in the connectors - they corrode and get dirty and fail to connect properly. Clean each electrical connector in the system and apply a slather of dielectric grease to it.
I met a fellow who went through 3 engine computers on his F250. Every time the mechanic changed the computer, the act of unpluggging it and plugging in a new one would remove JUST ENOUGH corrosion from the connector to make it work for another year or so. It was "fixed" but it never needed a new computer to begin with.
We unplugged the computer, cleaned the connector and put dielectric grease on it, and its worked fine ever since. Cost: FREE.
As for various sensors, you can test these with a simple volt-ohm meter and replace as necessary. It really is simpler than a carb. No analog adjusttments, emulsion tubes, diaphrams, needle jets, etc.
And let's face it, you are going to HAVE to learn how to fix Fuel Injection sometime, it might as well be now. Carburated cars are going the way of the Dinosaur.
Read some books on the subject and don't be afraid to give it a try. The offical FORD service manuals are helpful, but appear to be written in sanskrit.
Good Luck!
