Rear Gears
Old Sep 26, 2004 | 08:54 PM
grey77's Avatar
grey77
Rear Gears
i have 3.07 gears in the rear, of my 77F-100 2wd, and that just ant goin to cut it so i'm thinkin of puttin 3.73 gears an locking it up b/c i have some 28in. tires and they are still farley new but when they wear out then i want some 31in. swamper LTB's tires an i'll be i the mud a good bit, but it will still be a daily driver, so would it be better to have 3.54 gears or what. Because i still want it to perform good but i would also like the gas milage to be good also. Thankz for any responses
Old Sep 27, 2004 | 08:17 AM
mark a.'s Avatar
mark a.
If you are going to put 31" tires on it I'd put the 3.73 in it.
Old Sep 27, 2004 | 08:55 AM
77300i6's Avatar
77300i6
What engine/tranny combo do you have? I have a 77 4x4 with a 300/435 and 3.50 gearing. I stepped up to 31" tires and it had little effect on the perfomance, if anything it brought my rpms down a little bit, but not much. If I were to go to any size bigger (tires) i would cerntainly step up the gear ratio.
Old Sep 27, 2004 | 05:11 PM
grey77's Avatar
grey77
I have a 302/C4 engine/tranny combo. Would 3.73's be too much for the 28" tires ???
Old Sep 27, 2004 | 09:13 PM
SoCalDesertRider's Avatar
SoCalDesertRider
3.73's will be low for the 28's but will be perfect for the 31's. I have a 302/3-speed and 3.50 gears in my '69 Bronco with 31" tires and the 3.50's are a little too high. 3.73's would be just right.
renyren
25
May 8, 2018 12:41 PM
customtronic
Mar 21, 2016 11:28 AM
1974 f100
Jan 19, 2016 06:44 PM
johnstonmatt77
Apr 13, 2015 10:20 PM
Awsum77
19
Jul 31, 2005 06:16 PM
