Latest Tsb's
Old Sep 26, 2004 | 01:50 PM
emtabmm's Avatar
emtabmm
Post Latest Tsb's
04-19-04 Water-in-fuel (wif) Lamp
04-18-06 Driveability - No Start Or Constant Engine Misfire - Fuel Injection Control Module (ficm) Diagnosis - 6.0l Diesel
04-18-04 Turbo-induced Exhaust Moan/drone At 1600-1800 Rpm - 6.0l Built After 9/29/2003
04-17-13 Hard Start Or No Start - Gpcm Connector Service Kit Available - 6.0l Engine
04-16-08 Vacuum Pump Inoperative Or Runs Continuously - Climate Control Defaults To Defrost
04-14-12 Front End Accessory Drive (fead) Belt Noise - Vehicles Built Prior To 6/1/2004 - 6.0l Engine
04-13-08 6.0l Engine - Low Rpm, Buck/jerk, Miss, Stumble - After Deceleration Down Long Grade With The Cruise Control Engaged
04-09-04 Engine - Exhaust - Turbo-induced Exhaust Moan/drone At 1600-1800 Rpm - 6.0l Built Prior To 9/29/2003
Noise - Vibration - Turbo-induced Exhaust Moan/drone At 1600-1800 Rpm - 6.0l Built Prior To 9/29/2003
04-09-03 Driveability - Runs Rough And/or Low Power - 6.0l Diesel Engine Only
Engine - Fuel In Oil - 6.0l Diesel - Injector Diagnostics
04-09-02 Driveability - Water-in-fuel Lamp Illuminated After Draining Heated Fuel Conditioning Module (hfcm) - Vehicles Built Prior To 11/1/2003 - 6.0l Engine
Engine - Fuel System - Water-in-fuel Lamp Illuminated After Draining Heated Fuel Conditioning Module (hfcm) - Vehicles Built Prior To 11/1/2003 - 6.0l Engine
03-20-12 Driveability - Various Driveability Conditions - 6.0l Dit Engine - Vehicles Built Before 9/29/03 - Calibration Update - Running Change
03-20-10 Driveability - Fuel System - Injector Combustion Seal - Installation Procedure - Service Tip - 6.0l Engine
Engine - Fuel System - Injector Combustion Seal - Installation Procedure - Service Tip - 6.0l Engine
Old Sep 26, 2004 | 02:09 PM
jdadamsjr's Avatar
jdadamsjr
Sound like a lot...
but I've only had one of those issues... had the HFCM swapped out early on and have not had any other problems...
Old Sep 26, 2004 | 04:30 PM
twoballsleft's Avatar
twoballsleft
04-18-04 Turbo-induced exhaust Moan/drone At 1600-1800 Rpm - 6.0l Built After 9/29/2003
I got this isue going on right now...dealer says it's normal...yea right...why didn't it do it for the first four months? What's the fix?
Old Sep 26, 2004 | 05:19 PM
TLW's Avatar
TLW
Sounds like you have gotten them all fixed, cause it is now Sep.26, 2004 and the last problem you noted was on April 19, 2004. Sounds like you have a good diesel machanic. You may need to give him a X-mas present!!!. Tim
Old Sep 26, 2004 | 05:28 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Hell-o buddy how you been....quiet you have been
Old Sep 26, 2004 | 08:11 PM
twoballsleft
I've been doin just fine...thanks for asking...alot of traveling going on...flying to Orlando tomorrow morning if Jeanne lets me...what a mess that place is.
Funny thing, took her in for service last week...the drone...normal...the oil/grease on the front rims...normal...the clunk...normal...the wandering steering...normal BUT better than most...at least they changed the erl...I think...
...sending a sample to BlackStone...this should be interesting...probably come back normal...
Old Sep 26, 2004 | 09:49 PM
SBV45's Avatar
SBV45
Emtabmm, welcome back. Haven't heard in long time. Check http://www.intellidog.com/dieselmann/60bulletin.htm for the list. Is it accurate?
Mar 24, 2006 06:10 PM
khitch710`
Nov 19, 2004 07:59 PM
SBV45
Jun 29, 2004 06:10 AM
flounder
Feb 25, 2004 04:39 PM
emtabmm
Feb 24, 2004 06:15 PM
