Offroad & 4x4
dana 60 or 61?
Old Sep 26, 2004 | 10:43 AM
offroad464's Avatar
offroad464
dana 60 or 61?
What's the difference and are they interchangable?
Old Sep 26, 2004 | 11:00 PM
william_ace's Avatar
william_ace
wait, a 61? front or rear, whatcha talkin about
Old Sep 26, 2004 | 11:46 PM
fishmanndotcom's Avatar
fishmanndotcom
dodge and ford both used a Dana 61 rear but not for long...pretty oddball.
that's about all i know about them
-cutts-
Old Sep 27, 2004 | 12:09 AM
william_ace
ahhh learn somthin new every day
Old Sep 27, 2004 | 07:30 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
The Dana 61 was used in 2wd pickups and vans. It used a different ring gear carrier to allow higher gear ratios...3.21:1 and such. Trying to set up 'normal' ratio ring and pinion sets will get you nowhere in one of these housings....you'll have way too much clearance between the gear teeth. No, there is no interchangability (gears, housing, or carrier-but brakes, axles ok) with these axles, however, ring gear spacers are available if you absolutely have to run a D61 housing with 3.73/down gears or 4.10/up.
Cody
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
