95 explorer
Old Sep 26, 2004 | 01:33 AM
paragod's Avatar
paragod
95 explorer
My buddy has a 95' explorer, and he comes to me with most of his auto questions. The other day he noticed something hanging from the bottom of the truck, so he asked me. I checked and found an approximately 3/8" hose that ran to the top of the front diff. It attached at the top of the diff onto a rigid steel line that was about 2 1/2" long. The opposite end of the hose had a plastic fitting? on it. I honestly didn't know what it was, or what it did, so I zip tied it to the frame out of the way. His 4wd still engages, and he doesn't have any warning lights on. Any thoughts?
Old Sep 26, 2004 | 01:35 AM
85e150's Avatar
85e150
Breather vent for axle. Should have some kind of fitting to keep crud out, and be mounted high enough to keep water out.
Methinks.
Old Sep 26, 2004 | 01:43 AM
paragod's Avatar
paragod
That sounds right. The fitting looked pretty funky, but it fits the description. I gues where I mounted it can be its new permanent home, since it's out of the way and high enough. Thanks!!!
Old Sep 26, 2004 | 07:29 PM
paragod's Avatar
paragod
I moved the end of the hose up the firewall some to make sure it wouldn't suck water. I don't think there is much real danger, since my friend's truck has never, and probably will never see any mud that is not on top of pavement. Thanks!!!
