axle ratios
Old Sep 25, 2004 | 10:18 PM
smoke n tires's Avatar
smoke n tires
axle ratios
i have a 78 f150 460 with a 9in. i recently removed the gears to inspect and service the diff. i counted and divided the teeth on the ring and pinion and came up with a 2.59 ratio!!! i never heard of this ratio, has anyone else? i would like to change to a 3.25 but the truck will still melt the tires...
Old Sep 25, 2004 | 10:19 PM
Mil1ion's Avatar
Mil1ion
What was the teeth count on both gears ?
I think you have a 2.75 :1
Old Sep 26, 2004 | 03:26 AM
docholiday72tx's Avatar
docholiday72tx
If it is a ford 9 inch in a 78, chances are good it's probably 2.75:1. To my knowledge there were 6 gear ratios offered. 2.75, 3.00, 3.25, 3.50, 3.70, and 4.11.
Old Sep 26, 2004 | 09:52 AM
smoke n tires
the tooth count was 17 pinion, 44 ring. the gear is awesome on the interstate but it sucks in town.
Old Sep 26, 2004 | 09:54 AM
smoke n tires
the tooth count was 17 pinion, 44 ring. the gear is awesome on the interstate but it sucks in town. i figured it was a 2.75 but it doesnt add up.
Old Sep 26, 2004 | 10:33 AM
LxMan1's Avatar
LxMan1
It's probably actually 16 pinion and 44 ring gear = 2.75
Old Sep 26, 2004 | 01:02 PM
smoke n tires
your problably right, its hard counting pinion teeth when the gear is set up.. i still would like a 3.50 or even a 4.11 in town. that would make a big difference.i just have the truck for a work vehicle but i like to light the tires every once in a while.
