toyota steering box bracket
Old Sep 25, 2004 | 07:08 PM
Drool Monkey's Avatar
Drool Monkey
does anyone have the dimensions for a bracket to mount an 85 toyota steering box onto the frame of a 55 f-100 if so could you post it or send it to me?
Old Sep 25, 2004 | 09:02 PM
e william's Avatar
e william
Toyota Bracket
I just finnished the same project on my '54 F100. Turned out great, but I purchased my mounting bracket from "Mid-Fifty's" for about $95.00.
I,m sorry I did'nt measure before install but the one I bought did line both the pitman arm shaft and the steering column very well. It took alot of guess work out for a little bit of money. Hope this helps.
Also used a "I-Did-It" tilt column with billet drop and swivel floor mount
good luck, Ed
Old Sep 27, 2004 | 09:08 PM
Drool Monkey
anyone have some dimensions?
Old Sep 28, 2004 | 02:08 PM
Scott Hurley's Avatar
Scott Hurley
Thumbs up
I made one from a pic. in the mag. I just sold it, I installed a Aerostar front end. I'll call the guy I sold it to to get the demintions. I know it was 1 1/2" wide X 2" on the upper & lower flanges, 1/4" thick, the angle & height I'm not sure, I set the box in for that. I do know you have to weld a piece for the side to bolt to the side of the frame to keep it from flexing (I learned the hard way). The pitman arms I cut in two and welded them to gather to make the one. Again I'll call him and respond back soon. And I may still have the pattern.
Scott
Old Sep 28, 2004 | 11:55 PM
Drool Monkey
thank you so much. You have put the last piece of my night in place. This day was excellent! skippd school, and worked on my truck for a good 7 hours then had the best day at work, and fabricated boxing plates for my frame! My god this was a good day!
Old Sep 29, 2004 | 10:56 AM
Trader Bob's Avatar
Trader Bob
HI, I have a picture of PS box mounted to the bracket on my gallery. Bob
Old Sep 29, 2004 | 08:37 PM
hot1958's Avatar
hot1958
do they make a bracket like this that will fit on a 58' f-100.thanx/scott.
Old Sep 29, 2004 | 09:16 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Here's an article about the conversion, if you haven't already come across it:
http://www.geocities.com/zeener96/toyota.htm
-- Ross
Old Sep 29, 2004 | 09:44 PM
hot1958's Avatar
hot1958
hey/ross,thanx,this look's like a good idea.what power steering pump did you use.thanx/scott.
Old Sep 29, 2004 | 10:59 PM
Drool Monkey
i pulled my box out of an 83 toyota 4x4. ...it doesnt match up. it will work with some fab work, but not a bolt in. thanks anyway guys. .if i can find a simple fix to mount it, ill let you guys know and maybe some of you can use an early 80s toyoda steering box. it is toyoda btw.
Old Sep 29, 2004 | 11:48 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Scott, it's not my article, I haven't done the conversion. Sorry
-- Ross
Old Sep 30, 2004 | 07:00 AM
Scott Hurley
The bracket is easy to make, here's how it goes, I'll walk you through it. With the original steering in place mark the angle with a piece of tape, then remove the box. Measure the distance between the flanges of the frame....then add 1 3/4" to each end of that measurement. With the measurement cut a piece of 1/4" plate or strap 2" wide. Now measure in on each end 2"......I know you added only 1 3/4" but you have to allow for what they call set back and bend allowance...trust me. Then bend the piece on each end to a 45.....OPPOSITE OF EACH OTHER. Then with the new box in place fine tune the angles to the frame and mark the mounting holes for the box and frame, remember the box has to be snug up against the side of the frame for the pitman arm clearance. Then cut a triangle piece of 1/4" stock for the side support (to keep the bracket from flexing in the frame). this piece needs to cover about 3/4's of the angled area on the bottom side against the frame. Before you weld it up, you'll need to cut out some areas for the nuts to clear to mount the box. Is this as clear as mud? The pitman arm is easy just cut them both in half and weld them together. How easy can it be? I'm not sure how a 58's steering is set up, but if it's in the same configuration it should work the same. Let me know if I can help any more. Scott
Old Sep 30, 2004 | 07:16 AM
hot1958's Avatar
hot1958
hey/scott,thanx.i am pretty sure the set up is the same.it seem's that a lot of stuff carried over from the 56' model's,to the 57'-60' series of truck's.i am going to look in to this for my truck,thanx again/scott.
Old Sep 30, 2004 | 06:04 PM
1955effie's Avatar
1955effie
help
would someone tell me are they happy with the toyota box conversion ? how does it handle? really need some feed back on this . thanks
Old Oct 4, 2004 | 06:03 AM
Scott Hurley
It handles the same as before the conversion, the only thing is it's easier to turn. You still have the old suspention. You still have the road walk, the straight axle hop, and the over all rough ride. Now if you want it to have a smoooother ride and handle, you might try a diffrent front end, like I did. I went with the Aerostar. It took about 60 hours to do by myself in my garage, but well worth the time. The rack, and independent suspention is GREAT, handles, and a smooth ride. If your going to take the time to build the parts for the Toyota conversion, take a little more time and do the Aerostar. Take it from a man who's done both, it's well worth it. I payed 100.00 for the Aerostar subframe (complete with wheels, tires and swaybar),and I spent that for just the Toyota gear box, not including the materials for the brackets and time to figure it all out. Everything you need to know about installing the Aerostar in on this forum. Oh, I sold the axle, bracket, pitman arm, and box for 250.00, I made money on putting in the Aerostar front end. the Toyota is easyer but you'll like the Aerostar much better. Scott
