Help with code #121
Old Sep 25, 2004 | 05:57 PM
95f150's Avatar
95f150
Help with code #121
Hello all,
95 f150 4x4
302 5spd
I have been noticing problems with my truck which seems to be a throttle problem, its been like this for awhile. I pulled the codes today with a code reader and got code #121. I did the KOEO test. The manual says this code is " closed throttle TPS voltage higher or lower than expected"
Should i change out the TPS? or is there something else i should be doing? Thanks,
Rob
Old Sep 26, 2004 | 07:55 AM
EPNCSU2006's Avatar
EPNCSU2006
Test the TPS with a volt meter and see what the voltage values are. Measure between the green wire and the black wire with the tps harness plugged in, and the key on, engine off. Closed throttle should be right around .9V, and then voltage should smoothly increase to around 4.8V at full throttle. If the voltage change spikes (doesn't change smoothly), it's time to replace the tps.
87-XL-Squared
Feb 26, 2016 07:52 AM
Biker1966
2004 - 2008 F150
Dec 4, 2015 02:20 AM
clarkbre
Sep 4, 2014 07:37 AM
Lil Josh
Aug 31, 2013 07:38 PM
