Getting in gear after start up??
give us pics and pics !!!!
Every once in a while if I have the wheel turned wrong when I STOP the truck it will lock the wheel in such a position I can't turn the key unless I rock the steering wheel, (but that's my doofus showing more than anything
)but can't say I've had a problem putting it in gear... unless I don't pull on the shift lever back toward me enough to release...
maybe not pushing in the brake pedal enough ????
I just put pics in my gallery.
already got a lift and tires on there ?
what size are the tires ?
My favorite color if I can't have black !!!
My last sports car was bright RED !!!
Wanted them to see me and get out the way !!!!
The wheels are 20"x10" centerlines with 35"x12.5"x20" Toyo tires. I wasnt to sure about the 20" rims but I think they look pretty good and I was impressed with the Toyo tires, they are not to noisy, time will tell on wear.
And I also love black, I sold my Jeep Cherokee to buy this and it was black. But that would fit in my carport and it was cherry clean, I took care of it, no way this thing is going to fit so I chose a color that woud maintain easier.
Back to the original subject, does anyone else have an idea what could be causing my truck not to go into gear?
had 4 jeeps over the years...
started with cj-5, cj-7, cj-8, and traded my silver 98 5.9 AWD limited in on the Ex....
liked that jeep - but REALLY like the X....
I'd swing it back to Ford for a peek.. Maybe something they did when doing your mods.. 'Possibly' a problem with the column solenoid/shift tube assy.. Hard to say from here.. Would have to take a look, and start eliminating the possibilities.. Doubtful anything with the trans, but could easily be checked.. If you are stuck, can't pull it outta gear with the shifter, you 'could' set the parking brake TIGHT, engine OFF, BLOCK the wheels and 'pop' the shifter cable of the ball/lever at the trans.. It should easily 'click' into any gear..
What part of the Bay Area are you in?? I'm in the North Bay...
......................HP..............
Im in San Mateo...
........................HP..................
