Aerostar Ford Aerostar
Window Crank Removal
Old Sep 24, 2004 | 12:59 PM
himthere's Avatar
himthere
94 Aerostar, 3.0l. I want to replace my worn drivers side window crank mechanism. The guts are fastened to the door with 3 bolts which have a round button type nut that I cannot remove with anything. The heads of the bolts are inaccessable inside the door and don't feel like anything wrenchable. How are these bolts removed?? Special tools??
Old Sep 24, 2004 | 01:09 PM
copper_90680's Avatar
copper_90680
Are you sure those are nuts and bolts? Could they be rivets?
Old Sep 24, 2004 | 01:13 PM
himthere's Avatar
himthere
Not rivets. Can see what appears to be threads on the portion of the bolt that penetrates the "nut".
Old Sep 24, 2004 | 03:12 PM
aerocolorado's Avatar
aerocolorado
Those are a special type of fastener that resembles a rivet. You drill them out to remove, but you can use short bolts/nuts with threadlocker as replacements.
Old Sep 25, 2004 | 01:22 PM
himthere's Avatar
himthere
Thanks for the info Aero, I'll try it.
