Sounds like marbles
Old Oct 4, 2004 | 07:15 AM
  #46
debestuss's Avatar
debestuss
Originally Posted by WillyB
Sorry you are having trouble - and this is one lesson I will learn without having to repeat it for myself. I would have idled the engine when I first started it myself. I know it does not help, but you saved me from the same fate.
I am still worried about the rod side clearance issue. I read the chapter on rods and pistons in Christ's book and he never mentions it. Again, I would have assembled the engine and never given it a thought. To make sure I understand what has been said, you are talking about being able to slide the rod sideways on the wrist pin, between the bosses inside the piston?
And this has a clearance tolerance?
No, not the wrist pin, the crank. I had to buy a new crank when I rebuilt my engine but I didn't buy new rods. I can only tell you that, according to my situation, there is a clearance but there's no way to adjust it unless you go with new rods. I'm going to have to wait to buy new rods, I don't have the money for another rebuild. I will be taking it easy so as not to aggravate the bottom end. I think I've got some time because I don't hear anything outside of idle.
Old Oct 4, 2004 | 07:20 AM
  #47
debestuss's Avatar
debestuss
Originally Posted by Ratsmoker
Not only does the oil not get splashed Rusty but the cam needs RPM to get the lifters spinning. Idling is the worst thing you can do on a new cam besides running without oil.
I wish I knew then what I know now. This was the first engine I'd rebuilt. I didn't know where the oil plugs went so I missed one...the lifter gallery one. I ran it for a week with the oil light coming on at idle.
Old Oct 4, 2004 | 08:37 AM
  #48
debestuss's Avatar
debestuss
Anybody remember this? https://www.ford-trucks.com/forums/s...d.php?t=213242
Old Nov 19, 2004 | 05:59 PM
  #49
debestuss's Avatar
debestuss
I went with 15W-40 oil this time. I also pushed the collar up on the oil pump drive shaft to take out the slack. No more noise. Thanks everybody for now. If it comes back then I'll just...just....
Old Feb 6, 2005 | 04:26 PM
  #50
omarmowrer's Avatar
omarmowrer
my engine makes a similar noise only when it is warm. the only time i notice it is when the truck is in nutural. but if you push in the clutch the sound stops. if anyone has any ideas om what the problem could be please let me know.
Old Feb 6, 2005 | 11:52 PM
  #51
RustyTrustyF150's Avatar
RustyTrustyF150
Thumbs up
With the marbles question , I had a 71 F100 that sounded like a marble somewhere when I would rev the engine up . Later when I overhauled the
C-6 tranny I found a PIECE of aluminum in the torque converter housing
that looked like it could have been from the starter . Scared the heck out of
me when that piece would rattle in there .
xjpilot
24
Apr 11, 2017 04:48 PM
bigunit54
Nov 25, 2016 06:41 PM
Rob K
Aug 27, 2016 06:37 AM
steveflyswright
Jan 12, 2015 04:00 PM
P95Loser
Apr 26, 2007 12:30 PM
