Bronco II Ford Bronco II
Wet Headliner
Old Aug 13, 2002 | 07:43 PM
Volkl's Avatar
Volkl
Wet Headliner
So I've been browsing through the post and thought I found the answer. I sealed the "rain gutter" on the passenger side w/ silicone to no effect, my headliner still gets wet. Any suggestions? Only the passenger side corner get damp and only after a heavier rain. Thansk for any input you an give
Old Aug 14, 2002 | 09:30 PM
gypsyclimber's Avatar
gypsyclimber
Wet Headliner
I had the same problem...ended up running caulk all the way across top of the windshield as well as in rain gutters. I used clear caulk across joint where metal windshield trim meets body and metal trim meets glass. I also pulled that trim off first and caulked underneath where the windshield is caulked to frame...I probably went overboard. Note:this is just a work truck, so I wasnt too concearned about finish, could be a messy job.
Old Aug 17, 2002 | 12:57 AM
wantsabronco's Avatar
wantsabronco
Post Wet Headliner
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
17
Jan 29, 2015 01:55 AM
jyount
1997 - 2003 F150
Aug 11, 2011 11:14 PM
Futuresweets-10
Aug 30, 2010 06:10 AM
trinogt
May 21, 2009 09:48 PM
