Hole Saw
Hole Saw
Any chance anyone knows where I can find a 4 5/8 hole saw? I need it for a guage I'm installing. I have a 5" and have found plenty of 4 1/2 but I can't seem to locate a 4 5/8 anywhere. Oddly enough a 3 5/8 is very common.
ivanribic...I looked in both Grainger and McMaster-Carr catalogs, and their hole saws go 4 1/2, 4 3/4, and 5. The 4 3/4 would give you a bit of slop, but the least amount.
There's a Grainger in Spokane Valley (if that's near you), number is 509-457-1518. Look at 4 3/4 p/n 4XJ12 $36.25 (w/o arbor) or 4XJ80 $57.95 (w/ arbor).
McMaster-Carr's number is 732-329-3200. They're in NJ and give excellent service, but a little pricier than Grainger's. They'll ship it within a few days.
Another option is Aircraft Tool Supply (do a web search, or call 800-248-0638) . They have an adjustable hole cutter that goes from 2" to 12" and good for up to 16 ga metal. P/N is HC1 at $52.95.
Good luck!!!
Good luck!!!
Thanks for the heads up Don! I'll give Grainger a call tomorrow. I'm thinking I may go to 4 1/2 and then use my mini drum sander attachment to open the hole up a bit. I'd rather have it snug then loose. Still trying to figure out why Autometer has decided to use this size.
All,
If your cutting sheet metal, there is a common tool for cutting round holes any diameter up to 12" diameter. They are around $20 and you can get them at a heating/air conditioning distribution warehouse. I'll see if i can fing one and get you a path.
KingFisher
KingFisher
All,
Try this path and look on the third page.
http://gallery.bcentral.com/Gallery/...=181845&Page=3
It's $24.95 cuts up to a 6 1/2" hole.
Consider it,
KingFisher
http://www.malcotools.com/products/metalduct/hc1.htm
Consider it,
KingFisher
Try your local plumbing supply house. Thats the standard size for a 4" drain/waste vent pipe opening. Most plumbers would use a selfeed or auger type bit since they're cutting wood but some do use hole saws and it shouldn't be too hard to find.
I'm cutting 1/4 polycarbonate. I'm not thinking that universal bit would cut it well which is why I want a good hole saw. I think I'll try the 4.5" and then use a little drum sanding bit on the Dremel to open the hole up a bit if need be. I'm going to wait for the speedometer to arrive so I can test fit as I go but the instructions specifically call for 4 5/8 and I know on my tach there's not much room for making too big a hole.
Thanks for the help guys.
4sabre
Nov 24, 2020 09:40 PM
joe Ironworker
Feb 6, 2013 09:03 AM
bigred1997
Dec 28, 2005 08:01 PM
