Sponsored by: Auxito
Electric Seats
Old Sep 23, 2004 | 04:10 PM
lodown98's Avatar
lodown98
Electric Seats
I recently purchased electric bucket seats for my 98 f-150. My question is- Which of the two wires on the connector is the hot wire? My truck had simply a bench seat and these seats are from a 98 explorer. I simply want to run a hot wire and ground to these wires to get them to work.
Old Sep 23, 2004 | 07:48 PM
triton_2002's Avatar
triton_2002
Not 100% on this, but can't you just try it either way? If its backwards the motor will spin the oposite way than the switch is indicating. Then you can just reverse the wires if it was wrong. You could also use a 9V battery to test it.
Old Sep 23, 2004 | 08:21 PM
Racerguy's Avatar
Racerguy
What triton said is an easy way to check.
But if you dont want to check then the power is the bk/wh and the ground is the bk.
Old Sep 25, 2004 | 09:55 AM
lodown98's Avatar
lodown98
Thanks for the info! I did not think of that...I thought I may burn something up if I hooked them up backwards.
bbm10244
Oct 8, 2016 04:25 PM
oft
1997 - 2003 F150
May 22, 2015 09:38 PM
Marty N Debbie Sapp
1997 - 2003 F150
Jul 8, 2014 12:19 AM
Biggg72
Oct 30, 2013 07:13 PM
AndeyHall
Nov 17, 2011 07:10 AM
