Bronco II Ford Bronco II
bonco2 rear axle
Old Sep 22, 2002 | 05:56 PM
rick1857's Avatar
rick1857
bonco2 rear axle
I have a 89 bronco2. The tag is off the door post. would like to know the type of rear axle. The tag on the rear axle has 6070 on top of the tag an 10A756MO1 under it
Old Sep 23, 2002 | 10:08 PM
deerwchr's Avatar
deerwchr
bonco2 rear axle
There should be another tag attached to the cover bolts that states the ratio and a few other things. That's the tag you want for referencing.
Old Sep 23, 2002 | 11:12 PM
mrshorty's Avatar
mrshorty
bonco2 rear axle
6070 is the axle model number
10 is the gear ratio (I'm guessing there's a 4 missing probably 4.10 gears. L10 would indicate a limited slip so it's probably an open diff. check the gear ratio by spinning the tire by hand one turn and counting rotations on the driveline)
A75 indicates 7.5 inch ring gear
6MO1 is a production sequence code I think.
Old Sep 24, 2002 | 08:58 PM
rick1857's Avatar
rick1857
bonco2 rear axle
looked at the tag once more it's 4SL10A756M01. Is the slip better than a open one. I don't know any thing about them.
Old Sep 25, 2002 | 09:41 AM
mrshorty's Avatar
mrshorty
bonco2 rear axle
Limited slip differential has clutches in it that (usually) prevent one wheel from spinning while the other doesn't pull. Under certain conditions it fails to do so, but it improves traction by forcing both wheels to spin. The clutches wear out with time (I've heard they're usually good for about 30K miles), so there probably gone on your BII, so it's just like having an open differential until you can get in and replace those clutch packs.
Old Sep 25, 2002 | 06:34 PM
rick1857's Avatar
rick1857
bonco2 rear axle
In the six months had to replace the rear axle an rebuild the trans. Hopfully all I have to fix now is the 4 wheel drive it went in it once.
Old Sep 25, 2002 | 11:11 PM
blessedby6's Avatar
blessedby6
bonco2 rear axle
coyotero
Apr 7, 2008 06:45 AM
tonfro
Feb 20, 2008 04:31 AM
manyolcars
1983 - 2012 Ranger & B-Series
Dec 4, 2004 11:25 PM
KKClark
Feb 13, 2004 08:51 PM
whalerron
Jan 22, 2003 11:27 AM
