Instrument Lights
Old Sep 23, 2004 | 03:32 AM
jester34's Avatar
jester34
Instrument Lights
98 Expedition EB 4x4 what are the procedures to changing the lights behind the spedometor and other lights in that display????????????????
Old Sep 23, 2004 | 01:28 PM
dakota_viking's Avatar
dakota_viking
Jester
You need to remove the instrument cluster.
The cluster is very easy to remove. You have to remove the headlight switch, the cover just above the steering column, and the panel that houses the headlight switch and also goes around the cluster. Once that is out, just remove 4 bolts, 2 connectors and the gear display (just squeeze tabs and remove). With that, the cluster is out of the dash and in your hands.
It took me a total of about 14 minutes and that included disconnecting the battery (do this before you do anything else)
The bulbs can be seen on the back of the cluster.
Also:
Get yourself a Hayes manual...very useful tool!
Old Sep 23, 2004 | 07:41 PM
jester34's Avatar
jester34
thanks
I didnt think it was that dificult but I wanted to check with the forum first just to make sure.
Old Sep 24, 2004 | 07:43 AM
Phil056's Avatar
Phil056
Same thing is happening on my dash. A couple of lights decided to stay dark for ever!. Anyone know the type bulb to use in case I can't read the model # on the bulb itself??
Thanks!
