Bronco II Ford Bronco II
Fuel pump reset button?
Old Sep 15, 2002 | 11:03 AM
floppy99's Avatar
floppy99
does anyone know if an 86 bronco II has a fuel pump reset button?
Old Sep 15, 2002 | 05:57 PM
blessedby6's Avatar
blessedby6
There should be an inertia switch in the passenger side just under the carpet. Hope this helps.
Old Sep 27, 2002 | 01:25 PM
89_bronco2's Avatar
89_bronco2
where under the carpet passenger in the rear or in the front????
Old Sep 27, 2002 | 02:34 PM
blessedby6's Avatar
blessedby6
under the dash/glovde compartment towards the center, there should be an electrical comming out of the bottom of it with what looks like a button on top. The button will not actually depress unless the switch has been tripped. Pull the carpet back from the firewall about 3 inches and you should see it.
Old Sep 27, 2002 | 02:43 PM
89_bronco2's Avatar
89_bronco2
thanks your a life saver i havent tried it yet but im going to go try it i hope i dont need a new fuel pump thanks again if you have messenger and you want to talk sometime blue_crayon66(No Email Addresses In Posts!)
Old Sep 27, 2002 | 02:48 PM
blessedby6's Avatar
blessedby6
silverbullet6oh
Nov 4, 2016 07:30 PM
MauleOne
Feb 17, 2012 10:25 AM
geckocub69
1997 - 2003 F150
Jul 1, 2007 04:46 PM
gunslinger67
1983 - 2012 Ranger & B-Series
Sep 12, 2004 10:03 AM
Skipdaddie
Feb 6, 2003 06:50 AM
