Modular V10 (6.8l)
Exhaust studs missing?
Old Sep 22, 2004 | 08:57 PM
BK50's Avatar
BK50
I was changing my oil on sunday and when I was giving the engine a look over I noticed there were some missing exhaust studs on both sides and there was one broken off. This has been this way for awhile atleast it looks that way. Has anyone ever had this experiance or is this common? It doesn't seem to leak anywhere but I think I should get them replaced....
Bill
Old Sep 22, 2004 | 09:48 PM
10 pipes racing's Avatar
10 pipes racing
yup, is the exhaust leaking at all? any noise other than that sweat V10? you do have 20 studs, so if the gaskets arnt blown out, you do have some time to plan an attack. mine blew out and i went with headers. there are alot of threads about this if you do a search. if you do go ahead with the rapair, take the inner fenders out- have a couple of drill bits- a couple of easy outs- and plenty of time. this is nothing to rush, use good gasketsand hardware or you will have to do it again. (eg leaks) good luck.
Old Sep 22, 2004 | 10:08 PM
BK50's Avatar
BK50
It has a small leak when you first start it up but it goes away right away and it seems to be coming from the manifold to down pipe. I probally won't mess with the one broken off stud but may just screw in the others.
Bill
Old Sep 22, 2004 | 10:18 PM
10 pipes racing
be gentle, hose them down with your favorite penetrating oil. should get ya down the rode for quite a while.
Old Sep 22, 2004 | 10:42 PM
LANEGRA99's Avatar
LANEGRA99
go easy on the srewing in part i think the others broke off because of the tension created when the manifold expands while hot. i think its just best to leave them alone untill you really have to touch them. helpfull hint if you have to remove the manifolds do yourself a favor and remove the fender wells you wont even have to work over head its alot easier to get to the manifolds from the side of the truck.
