New K&N filter and mileage drop? Normal?
Fred, I made the mistake of buying a 98 Ram 1500 with an auto trany wich I traded in on my V10 in 01. That POS had one good feature. I could controll torqe converter lockup in 3rd and OD with the OD on/off button. I have really missed that feature and would love to be able to controll the lockup manually while towing.
The benifits such as: unlocking in third while pulling a hill rather than down shifting to second when it's just not needed. Or the same for second gear acceleration when the converter locks up too soon and starts lugging the motor.
I'm talking about steep hills while towing 6000 to 9000# here in the Pacific North West
that most flatlanders would call mountains. Running empty you just don't hardly notice the problem with the factory trany tune.
Please tell us where to get the manual controller!!
Thanks, Ed
Thanks, Ed
Originally Posted by Bob Ayers
does anybody really think a manufacturer would design an intake system that would cause a decrease in performance, or gas mileage? I don't think so!!!
Ok torque Converter lock mod.... here is a link.
Caution, disclaimer, at your own risk, and other cover my *** statements. This is a very dangerous modification that I did just to get good dyno runs with.
Others use it on purpose on the road. I do NOT and here is why:
If you manually lock the torque converter, and have to stop right now, you are going to stop permanantly until $5000 or more is expended to replace your very broken trany.
If you are manually locked, and doing power burns, when the trans shifts up or down the shock and torque is more than the internals were designed to handle and things WILL break!
http://www.forgotton.net/mods/tclock/index.htm
Seriously be careful with this, and trust me, Ford will know, so kiss the trans warranty goodbye!
Fred, I am sure that the trany will shift now while the converter is locked. At least mine does. I think that while in Low Range it locks up on compresion as sometimes when I come to a stop it will kill the engine.
I am after a mod that will allow me to unlock the converter manually rather than lock it. I would like to interupt the signal to the converter when it is calling for a locked condition, at times. But let the ecm decide like stock at other times.
OK, I know this has thread has changed a bit, but I just checked my mileage again. It is back to the MPG it was, but the fuel gauge moes much faster now. I still only got to 80 miles when it was at 3/4 filled it up at 100 miles and only squeezed 8.8 gallons into it, and again that is till there is fuel in the filler tube. How does the gauge determine the fuel in the tank? Is it calculated, weighed, or is there a float? It just confuses me that the gauge changed this much but not the mileage. Ideas?
It also could be an over oiled filter which causes the pcm to apply more volts to maintain a certain temp of the mass air wires which fools the pcm into thinking more air is moving thru engine than what actually is flowing in, the pcm then adjusts fuel with pulse width on the inj's causing a slight loss in mileage,or it could simply be more air, more fuel.
Wash it and apply a light coat of oil.A lot of people have had problems with too much oil,but your right, it should have come w/proper amount of oil,but you never know.To clean the the mass air wire i spray a little starting fluid to degrease it, plus it evaporates good.Wind,air pressure can effect mileage very easy also.I would not worry about it if it runs good, mileage is not it's strong point.
