I had about 40xxx miles since last tune up. When I first did it, when I bought the truck. My best mpg was about 290 miles out of one tank (driving slow). Over time it has dropped went down to about 220 miles per tank. So I went and did a complete tune up. (Plugs, wires, cap, rotor, PCV valve, and cleaned out the K&N filter.) After doing this, it got worse! I was getting about 200 or less per tank. It did this for about 8 tank fills.
Today I swiched over tanks and checked my mileage and I got 265 miles out of one tank. Which is very good I think for the way I drive, 80mph on higway 40 miles a day. And stop and go 25 miles a day. (I got around 15-16 mpg) NOW what do you think went wrong here? EGR maybe? I know its original. As far as injectors, distributor, there all new within the past 15000 miles. I have 189,xxx miles on the truck now. Let me know what your take is on this. I would like to get this fixed. This $3.00 a gallon sucks. [img]images/icons/icon8.gif[/img] What is all of your typical MPG, differences after tune ups?
Which tank gets 200 and which gets 260? There is a problem wit the dual tank system that allows fuel to be pumped from one tank to the other while driving. If the tank is full it just shoves it out the filler neck and it's lost. The rear tank on my truck siphons gas out the filler at speeds over about 70 mph. It will suck out nearly 1/3 tank on a 4 hour drive. To fix it I just make sure I empty the rear tank first.
