Brake Controller Plug Where?
Old Sep 21, 2004 | 03:05 PM
tadpole88's Avatar
tadpole88
Angry Brake Controller Plug Where?
I have purchased an electric brake controller and pigtail and have the tow package installed on my 04 F150 but cannot find the wiring under the dash to plug the pigtail into, can anyone help? I have searched from drivers side door to transmission tunnel and have had no luck. I was told that on some F150s it is tucked into the trans tunnel but could not find it there either.
Any help locating this plug will be greatly appreciated.
Thanks
Mike
Old Sep 21, 2004 | 03:14 PM
Cincy F150's Avatar
Cincy F150
In your glovebox or map pockets there should be a baggy with the factory supplies pigtail. This will map out the plug-ins and such. From what I remember, the plug-in is below the tilt wheel. There is also an extra resister in the packet from Ford. Something to do with charging you trailer battery if equiped.
Old Sep 21, 2004 | 03:39 PM
14u2nv's Avatar
14u2nv
the plug you are looking for is under the steering wheel panel
Old Sep 21, 2004 | 03:57 PM
4WDuty's Avatar
4WDuty
..and it's wrapped or strapped to some of the framework under there. When you remove the dash panel, and you are looking at the steering wheel, it will be on your right side just to the right of the right opening edge. Good luck!
Old Sep 23, 2004 | 11:25 AM
bossracer's Avatar
bossracer
I found the factory connector just to the right of the steering wheel. Under the dash. I didn't have to remove anything. It was a tan-ish color. Just get down under there and take a look. It was behind another, smaller connector.
On the left side of the steering wheel is a steel bracket to mount the brake controller on. Very slick. It took all of 10 minutes to hook it all up. I bought a progidy brake controller with a Ford wiring harness. It plugged into the truck and then plugged into the controller. Did not need the factory supplied in the glove box wiring at all.
Cheers,
Dan
Old Sep 23, 2004 | 11:47 AM
psy61's Avatar
psy61
Here's a link to a pic I took of mine. It's inside the red box...
https://www.ford-trucks.com/user_gal...=55140&width=2
Jeff in NJ
2004 F-150 XLT SCab
5.4L, 373 rear, 6.5 bed.
24' Sun Valley "Road Runner" TT
Big smile on my face...
Old Sep 23, 2004 | 11:49 AM
lardman's Avatar
lardman
it is rectangular in shape and looking in the end, it has 3 pins down one side and 2 on the other. It is mounted on a IP bracket close to the trim.
mike69293
2004 - 2008 F150
May 26, 2008 12:20 PM
bgbully
Apr 1, 2007 09:22 AM
Ranger1F150
Feb 12, 2007 10:16 AM
Diesel Digger
Dec 7, 2005 08:05 PM
trolltap1
Jun 8, 2004 07:02 PM
