Clutch
Old Sep 21, 2004 | 01:44 PM
Spurs2966's Avatar
Spurs2966
Clutch
I have a 99 PSD and when the clutch pedal is depressed for a while or used repeatedly (like backing up to a trailer) the clutch disengages as if there is no clutch. If you release the pedal and wait a second or two and depress it again everything is fine. The more frequently the clutch is used the more problems, but give it a rest and it works perfectly. I have not noticed any slippage when pulling a load. The truck has 90K, I was told the slave cylinder is the problem. Any advice would be helpful. Thanks.
Old Sep 21, 2004 | 03:02 PM
basstardo's Avatar
basstardo
Slave cylinder is going out. Pretty common on these trucks...
Old Sep 22, 2004 | 09:38 AM
psdpower's Avatar
psdpower
Spurrs, welcome to FTE. Yeah it sounds like a hydraulic problem to me too. You can purchase the complete hydraulic system for these trucks from Ford for around $100, they come prebled and ready to install. They don't even require any tools, the master cylinder is held onto a bracket off the firewall with push pins and the slave cylinder goes into a whole in the bellhousing twist about 45 degs. and it locks in place.
Old Sep 29, 2004 | 10:18 AM
Spurs2966's Avatar
Spurs2966
Thanks for the info guys, I think I will go with the complete system, talked to Ford this morn and he's got one in stock.
