78 Fuel Pump Problem
Old Sep 21, 2004 | 12:10 PM
78BillF150's Avatar
78BillF150
My truck has been a bear since I first got it, but it decided to run so well that I became proud of it. Now, I've had to replace the fuel pump, which went without to many hitches, though it's doing an overkill.
My manual said to make sure the bracket (arm) went over a particular spot when installing and it seemed to only go in one way, that there wasn't any other way that it could possibly go and everything line up. Got everything put back together, but now I have gas pouring out at the carb, over-flowing onto my engine. Is there a trick I couldn't find in getting the arm back in, or have I created another problem or found an old one even?
Old Sep 21, 2004 | 01:04 PM
77460f150's Avatar
77460f150
This sounds like a stuck needle (open) in the float bowl of the carb. Some times you can get a small peice of dirt stuck between the needle and seat, allowing the fuel flow to continue and flood the float bowl. It will then spill out the vent tubes and into your engine. Once in a while you may be able to "tap" on the float bowl at the needle and seat area to dislodge the stuck object. You may have to remove the carb and take it apart and clean it out. -Ed
Old Sep 21, 2004 | 01:21 PM
John24255's Avatar
John24255
78BillF150,
If the fuel pump is pumping, you installed it correctly. Like 77460f150 stated, stuck needles are a common problem with carbs especially if the vehicle has been sitting for some time. You may wish to try tapping on the carb near the inlet tube first, use the handle of a screwdriver and tap lightly. If this doesn't free it up, remove the screws on the upper plate of the carb and verify that the float and needle valve work properly. This can be done without removing the carb, but be especially careful that you don't drop a screws down the intake!
Best of luck,
John24255
