coolant temperature sending unit
Old Sep 20, 2004 | 10:29 PM
dino360's Avatar
dino360
Angry coolant temperature sending unit
I am trying to find the name of a part on my truck. I have an '88 Bronco with 5.8. Next to the distributor is a small peice that screws into the intake. It is about the size of a 3/4 deep socket more or less. It is more of a hexagon shape instead of cylinder shape like a socket. This piece is where the temperature sending unit is located and also it has a small nipple that connects to a rubber hose which brings coolant to the throttle body. If anyone knows what this piece is called, I would appreciate the help. Mine is rusted out and I can't ask for it at the parts store if I don't know the name of it.
Old Sep 22, 2004 | 09:45 PM
paragod's Avatar
paragod
Get a hanes manual and check the component location pictures. I know that sounds like an over-simplified answer, but unless it's an "aftermarket" installed piece, I don't know. I'm not familiar enough with new Fords to give a great answer.
Old Sep 22, 2004 | 11:55 PM
hdgapeach's Avatar
hdgapeach
If no one chimes in with the name/part number call your local Ford dealer and ask someone in the parts department. With the description you gave, they will be able to tell you the name of it and what the Ford part number is and if he has any in stock. You can use the part number at any chain store for a cross reference for what they have.
Old Sep 25, 2004 | 01:30 PM
dino360's Avatar
dino360
Angry
I went to Ford and the part is called a hot water tube. It costs about sixty bucks. Thanks for the input.
Old Sep 26, 2004 | 12:28 AM
kinnja's Avatar
kinnja
Unfortunately, Haynes and Chilton's aren't always very reliable. This thread is a good example:
https://www.ford-trucks.com/forums/s...d.php?t=276104
Thumper47
1983 - 2012 Ranger & B-Series
Mar 27, 2013 04:51 PM
WillsF100
Jan 23, 2011 09:56 PM
thartweger
15
Jun 14, 2010 07:42 AM
t.Rowley
Nov 2, 2007 12:32 PM
DaleG1970
Dec 29, 2005 10:57 AM
