ok now some of you may be skeptical of this but i know it works. i did this. ok you hate micro amp (60 amp) alternator that came in the b2 cause you want a big bumping thumping flash the lights system. ok heres what you do.
cost $60
1. go to autozone.
2. get alt for 89 tempo (75 or 80 amp will fit)
3. get a one gauge wire.
4. mount alt
5. when reconection tap your to big fat wires and run the one gauge wire.
6. put the fat wire on your bat positive post.
i havent run the heavy wire on myne (yet) but it should work just fine. i dont think it would be any other wire since there all to small. so this should give you a steady stream of power and low resistance plus three paths for electricity so everything shold be powerd good and even. have fun with this one let me know how it works out for you....
