Under Body Dangly Thing
Old Sep 20, 2004 | 06:57 PM
crummy trk's Avatar
crummy trk
One of the trucks I drive for work has a square rubber mounted (isolated) dangly thing that is attached under the tranny. It's located (attached) on the rear tranny crossmember by the two studs, The two in the center that mount the tranny to the crossmember. The unit is made of steel and rubber. OK, this sounds like I'm describing the mount but It's not. It hung down 4" or so. The truck is a 88 F-350 4x4 Diesel Crew cab longbox that was shortend to a short box. What was this thing? I took it off, It hung up going through cross ditch's and the like.
Thanks, Derek
Old Sep 20, 2004 | 09:11 PM
Dieseldan7.3's Avatar
Dieseldan7.3
Was it like a rubber strap? It may have been for a spare tire in a very strange spot. Just a wild guess.
Old Sep 20, 2004 | 09:18 PM
crummy trk's Avatar
crummy trk
Nope, Was in the middle of truck. It looked as if it belonged there, for the life of me I don't see its purpose. Steel outside with a rubber isolator and steel again.
Old Sep 20, 2004 | 09:39 PM
horton-racing's Avatar
horton-racing
If I remember right, it`s a vibration damper for the automatic tranny.
Old Sep 20, 2004 | 10:44 PM
horton-racing
It bolts to the bottom of the cross-member using the tranny mount bolts. I have seen them only on automatics, no manual trannies, though that doesn`t mean they aren`t out there. I personally don`t understand how it`s supposed to work. To me, it`s just extra weight hanging down and an obtrusion just waiting to get you hung up on something, not to mention, unsightly.
Old Sep 21, 2004 | 06:02 AM
bilder12's Avatar
bilder12
May have been the old carrier bearing for the long drive shaft. Didnt you say it was shortened?
Old Sep 21, 2004 | 09:32 PM
crummy trk's Avatar
crummy trk
The truck does have a automatic in it, Vibration damper....? My other crummy has an automatic as well, minus the thingy. It's not a carrier bearing. What kind of vibration would such an external attachment dampen?
Old Sep 21, 2004 | 09:46 PM
horton-racing
It`s supposed to somehow dampen harmonics from the tranny if I remember correctly. Don`t ask me how. I`ve had them on 1986 F350 Diesels w/C6 and 1986 460 Gas w/C6. My parts manual even shows them on some 1986 I6`s, 302`s and 351`s though I`ve never seen them. It is actually called an insulator. It`s junk as far as I`m concerned. I always assumed the tranny mount absorbs the vibrations but I guess it is just for flexible mounting and is actually called the rear engine mount in the parts manual.
Old Sep 22, 2004 | 12:02 AM
crummy trk's Avatar
crummy trk
We are in agreement, its already in the scrap bin.
Old Sep 22, 2004 | 11:37 AM
rstcso's Avatar
rstcso
Are you sure it isn't there to catch any parts that might fall off while going down the road . Just a thought.
Brent
Old Sep 24, 2004 | 02:23 PM
kstark's Avatar
kstark
Smile
My dad owns a 92 Ford diesel with a manual transmission and the dealer told him that it was a dampener, although it worked better in snagging grass, trash ect.
