pushrods
Old Sep 20, 2004 | 03:14 PM
bigginsf250's Avatar
bigginsf250
pushrods
hi guys, i just recently rebuilt a 1974 390 and put it in a 78 f250 4x4. I bored it out .30 and put in flat top pistons that are 9.5:1 and a 282-292 duration cam. the problem is now that the motor has about 2 miles on it and has bent three pushrods.the original cam was a 260h, so i am not sure of what lenght my pushrods are now. any ideas?
Old Sep 20, 2004 | 04:09 PM
rusty70f100's Avatar
rusty70f100
Did you use the stock non-adjustable setup?
Old Sep 20, 2004 | 04:25 PM
Annihilator's Avatar
Annihilator
what is the lift on your cam?
Old Sep 20, 2004 | 04:31 PM
bigginsf250
yes i used stock rocker rails and the lift is .480 intake and .512 exhaust
Old Sep 20, 2004 | 04:38 PM
debestuss's Avatar
debestuss
Were you absolutely sure you had the pushrods seated on the lifters? It doesn't sound like your cam is too big. Did you go with longer pushrods?
Old Sep 20, 2004 | 04:41 PM
bigginsf250
no i used old pushrods
Old Sep 20, 2004 | 04:46 PM
debestuss's Avatar
debestuss
How long are they? Do you see where I'm going with this? The pushrods you had were maxed out with your original cam. Then you went to a more aggressive cam and ended up with too much pushrod. Just my .02.
Old Sep 20, 2004 | 04:49 PM
bigginsf250
no idea what size they are but yur sayin i need shorter ones tho right?
Old Sep 20, 2004 | 05:39 PM
debestuss's Avatar
debestuss
It's just an opinion. Take one of your original pushrods to a parts house and compare it to the different sizes or go to a machine shop and have them measured. I wouldn't take what I'm saying as a remedy until some of these other guys chime in with their .02.
