Tearing apart some C-1AE heads
Old Sep 20, 2004 | 02:45 PM
Annihilator's Avatar
Annihilator
I don't know if you guys remember this but last spring I took these off of a 390 that blew a head gasket. I went to the junkyard last week and they were still is the shop where I had set them! I told the guys there that I was going to take them apart and magnaflux them, check them for warpage etc, and if I decide that I want them that I will come bring them the money and if not I will bring them back. I just have some questions with these heads.
1. Will the ports line up with my Performer RPM intake, I know that the intake holes are a lot smaller that the opening in the head.
2. These combustion chambers have a D-shape and I have been told that the sharp corners make an engine detonate easily??? I currently have 198 to 200 psi cranking pressure with my C-8AEH/D-2TEAA head combo.
3. I will cc the chambers on the C-1's to see how much bigger they are, and may run a steel shim head gasket to keep the compression up but then I am going to put in a bigger cam to so....
Old Sep 20, 2004 | 04:05 PM
rusty70f100's Avatar
rusty70f100
To see if the head ports will line up with the intake, use a gasket. Lay it on the intake, measure how far the metal is inside on all edges, then lay it on the head. You want the port on the intake manifold to be slightly smaller than the port on the head.
Hope this makes sense.
Old Sep 20, 2004 | 04:22 PM
Annihilator
It does, I know that when I compared the opening of the intake manifold port to the opening of the intake runner in the head the one on the manifold was quite a bit smaller. I have also heard that opening up the intake manifold hole creates a pressure drop in (gasket matching)???
Old Sep 20, 2004 | 05:11 PM
rusty70f100
In that case I wouldn't worry about it. The difference will create a beneficial air dam, preventing reversion.
Old Sep 20, 2004 | 05:26 PM
Annihilator
Did BB or anyone else ever find the flow numbers for these heads?
Old Sep 20, 2004 | 07:21 PM
rusty70f100
I have some flow numbers for C4's but nothing for C1's. Should be interesting to see.
46yblock
72
Jan 25, 2011 10:24 PM
chucks blazer
Nov 20, 2004 01:12 PM
dhickey
Aug 27, 2002 09:50 PM
BlueOvalRage
Feb 22, 2002 11:23 PM
