occasional slip
Old Sep 20, 2004 | 11:27 AM
daerhldgs2's Avatar
daerhldgs2
occasional slip
I ahve a98 Exploder with 4 spd. auto , vary rarely it seems to slip or fail to hook up in 1st. and the rpm will climb but when the throttle is backed off it will hook up and shift fine , once or twice this has happened in reverse. I recently changed fliud and used a fliud(snythetic) that was compatible with the ford fliud for thisd trans, could this be the problem??
