Engine/Tranny Match-Up!
Old Sep 20, 2004 | 11:27 AM
StrangerRanger's Avatar
StrangerRanger
Hey guys,
I have a '88 Ranger 2.0L 2WD.
I'd like to drop in a '84 2.8L, but I don't know if it will match my current 5-speed tranny.
The 2.8L is in a 4WD.
Short of pulling it and dropping it in to see, where can I get info to see if the 2.8 can use my current 5-speed?
Old Sep 20, 2004 | 03:48 PM
racsan's Avatar
racsan
i would check with a local salvage yard, they should be able to tell you if both engines would use the same transmission. is the 2.8 in good shape? i drove a bronco II once with a 2.8 and though it was a rather doggy motor, my '88 had a 2.3 4 cyl that felt more like a V-6 than the 2.8 did. good luck with your project. Dave.
Old Sep 21, 2004 | 09:10 AM
StrangerRanger
I'll do that Dave, Thanks
My 2.0 has a pretty bad Head Gasket Leak, and with the work involved, I figured I'd rather switch up to the 2.8, which is being donated!
I didn't want to go for the 2.3 or the 2.9 because that would mean switching to fuel injection and more computers.
All in all, I hope the 2.8 will just run as good as my illing 2.0
tyco85
Oct 29, 2008 09:09 AM
blue97flare
Nov 14, 2006 08:35 PM
frankwest
Jan 4, 2006 08:22 AM
runemaster
Dec 25, 2005 03:14 PM
1_fishslayer
Feb 23, 2001 11:46 AM
