Cathletic Converters+ turbo muffler
also, loosing that .343239483274th horsepower doesn't bother me , I had to run just the cats for a while ( a day) and noticed no decrease at all, and noticed no increase when I put the t-muffler on there either, don't you just love the 2.9!!.
Charlie D.
Hi, my suggestion is go to the local 4 wheel, or one of the local speed shops. Sounds like you already have the larger pipe after the muffler, thats good, but it won't give you anymore horsepower at all. What I did was to install a high flow, high performance exhaust system from the outlet of the exhaust manifold to the tail pipe. Forget headers,difficult to install (if you can find them) and in my opinion not much horsepower gain. Stick with the stock exhaust manifold. The high flow system consists of a high flow catalytic converter that attaches to the existing exhaust manifold, then a high flow muffler, and a complete set of 2 1/2" pipes thru-out. Also, if you install the high flow exhaust you have to install a high flow air inlet. Which was simple, just replace the existing paper air filter, (I have the 2.9L fuel injected Bronco 2)with a new K&N air filter. My GOD, I picked up alot of horsepower! Made that Bronco2 darn scary when passing gear kicked in on the freeway. Seemed like it was going to leap in the air! First time, my auto transmission went into passing gear I almost had a heart attack. That Bronco2 was a screaming banshee changing gears at redline on the tach. Wow! I didn't like it so loud so I installed a pipe resonator between the muffler and the tailpipe. That lowered the volume a bit, and but also cut the horsepower down some. Still overall, the pick-up in horsepower was impressive, I'd say at least 20%. Takes a mild mannered Bronco and makes it a screamer. My gas mileage dropped by 1 to 2 miles per gallon,in city and highway when I drive it hard. I did also put in a new set of spark plugs,and set of plug wires, to make sure I had a good spark. Pretty amazing, the fuel injection and the computer adjusts for best ignition, emissions,etc. If you have a carb Bronco, you might need to increase the jet size, or at least the needle size on the carb, but with fuel injection, just install and forget.
The problem with the Bronco 2 is most of the horsepower of the engine is not available since they restricted the exhaust system so much. After the mod, most of the horsepower is available, I could go to redline easily on the tach like I said. I have the 89 fuel injected Bronco2, and did not make ANY changes to emissions systems, black box, etc,. All I did was install a new high flow exhaust system. The K&N air filter improves the air flow to the engine, but without a high flow exhaust there is only a slight gain in horsepower. Also, unless you install a high flow catalytic converter, the exhaust system is still radically strangled. SO, you have to make the whole modification to make a difference.
I put the K&N air filter set in myself,(easy), but had a shop remove the old exhaust system and install the high flow cat, high flow muffler, and larger pipes. The high flow muffler gives a low throaty rumble, just too loud for my taste. Like I said, the whole mod increased my top end on the highway, and took me to redline on the tach! After I put the resonater in, it decreased me about 600RPM. Interesting side note is really improved horsepower at higher altitudes,scrambles really nice at 8,000 ft, but I live at 1,000 ft elevation. I recommend the change. If you have access to welding torch or have a shop, the work is easily done in a garage, but forget wrenches, you'll never remove all that old pipes cause they are welded and rusted. Cost was about $650 installed I think and worth every penny! Plus, my emissions look better than a new car with that new high flow catalytic converter! I found out that this type of mod is pretty standard for anyone wanting more horsepower. The shop I went to did all kinds of 4 wheel vehicles that needed to meet emissions and wanted better sound and more punch! Call around and good luck.
If you really want to open the exhaust up, get a set of headers, split the exhaust and run 2 Flowmasters on there. That along with a K&N filter with the 86-87 TB will give you all the air you can use.
But a simple dual exhaust would help it out.
Osin - yeah, dual 2 1/2" on a 2.9. Ludicruous to some -- however, if you're going to do what I plan on doing, it'd be easier to squeeze out that 200+ hp if you had a large enough exhaust to let 'er breathe
As it stands, www.tsperformance.com is the only place I've found that can sell you a custom performance chip and there aren't many 'generic' or otherwise plug-in tuners for these ECUs. Although, my research is far from over
I've done tons and tons of research on these things. The dual 2-1/2" exhaust on the 2.9's do add a bit of power, and sound good too. It's all about the personal preference.
