Release Bearing Removal/Installation
Old Sep 19, 2004 | 10:33 PM
Brandan78's Avatar
Brandan78
Question Release Bearing Removal/Installation
Im having trouble removing the release bearing on my 89 for ranger 4x2. someone told me theres a special tool. Does anyone know what kind of tool this is?
Old Sep 20, 2004 | 05:39 AM
EPNCSU2006's Avatar
EPNCSU2006
Do you mean release bearing or pilot bearing? The release bearing just rides on the input shaft of the transmission. The pilot bearing is in the end of the crank on the engine. You can borrow a puller from auto zone to get it out, or you can pack the hole with grease and tap a dowel in there to make the grease force the bearing out (dowel must be the same diameter as the inner diameter of the bearing for this to work properly).
Old Sep 22, 2004 | 08:19 PM
Brandan78's Avatar
Brandan78
Release Bearing. It requires a special tool to remove. We couldnt get one so we had to change the whole clutch slave assembly. Thanks guys
Old Sep 22, 2004 | 11:03 PM
EPNCSU2006's Avatar
EPNCSU2006
Oh I see what you mean now. I didn't know the release was separate from a concentric slave. Glad you got it fixed.
