engine cubic inches
Old Sep 19, 2004 | 01:59 PM
Black89F150's Avatar
Black89F150
engine cubic inches
Hello;I am looking at a 1970 model pickup with a vin number of F10YNH10990,
could you tell me from the vin number what size engine it has?I think it is a 390 with a 2brl.carb.It has a working 8 track tape player.Wonder if EBAY has any 8 track tapes?That is my next stop.Thanks for your help.
Jack
Old Sep 19, 2004 | 05:50 PM
Little Bro's Avatar
Little Bro
You can find 8-track tapes at thrift stores, St. Vincent de Paul, Goodwill, Salvation Army, etc. Unfortunately, most of them have deteriorated foam pads that hold the tape against the player heads. If you have the patience to fool around taking the tape cartridges apart, you might be able to replace the old pad with a new foam, maybe from weatherstripping. Will require some ingenuity. The 'restoration' might last only long enough to play the tape a few times. Maybe you could dub the music off onto cassettes if it's 'must have' stuff.
Old Sep 19, 2004 | 07:31 PM
GolferSA's Avatar
GolferSA
Originally Posted by Black89F150
Hello;I am looking at a 1970 model pickup with a vin number of F10YNH10990, could you tell me from the vin number what size engine it has?I think it is a 390 with a 2brl.carb
Jack...
[bold]Results for VIN#: F10YNH10990[/bold]
Model Year: 70
Series: F100 - 4x2 Pickup
Engine: 8 Cyl, 360ci, 2bbl
Assembly Plant: Norfolk
Transmission: No code selected
Front Axle: No code selected
Rear Axle: No code selected
If you'll get the axle and transmission codes of the ID plate you can go here and get info on them:
http://www.medicine.wisc.edu/~mrm/bronco/ftvin.cgi
Regards...
Old Sep 19, 2004 | 07:35 PM
boneman01's Avatar
boneman01
The "Y" shows 360 in my book. Unfortunately, the only way to tell the difference in the engines is to measure the stroke. It may not even be the original engine since it's almost 35 years old. Either way, they both are pretty good motors, but they like their gas. Good luck with it (and the 8-track). You might be able to donate the 8-track to a museum for a tax write-off.
albertatyke
6.2L V8
17
Jun 5, 2013 09:55 AM
ungerp
Oct 7, 2011 04:06 PM
bigwin56f100
16
Dec 16, 2008 10:50 AM
red03SVT
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Oct 2, 2003 02:42 AM
Cool32
15
Aug 22, 2003 07:35 AM
