Sponsored by: Real Truck
Smoke at start up...
Old Sep 19, 2004 | 01:12 PM
wickdgt's Avatar
wickdgt
Hi there guys, I have an 03 F250 SC SD with the V10, it has now 10,000 miles now. I have notice that once in a while when I start up the truck in the morning, a puff of blue smoke comes out of the tail pipe, and then nothing on the rest of the day, this may happen sometimes not all the time, can anybody tell me what is going on, are the valve guides leaking oil? Another thing is, I went to buy 5w20 from the Ford dealer and the guy gave me 7 quarts, and ask him why, it only takes 6, he said that it takes 6 1/2 quarts, is it true? Cause I did put 6 1/2 quarts. Another thing I found is, that when I step on the truck one wheel spins, the right side, so I put it on the jack and had my son hold one tire while I spun the other, I could not make it brake loose, so the traction clutches are working, but how come it does not show it when I step on it from a dead stop, I can see doing the spun when I put it on reverse, then the left tire smoke the tire???? When I turn, I can hear the left tire graving the road, so is my traction lock working, it has to be because I could not broke loose one side when we where trying to turn the tires by hand. Thanks for any help guys.
Edgar
Old Sep 19, 2004 | 01:34 PM
Autobahn F-250 Lariat's Avatar
Not sure about v10 but my 5.4 takes 6.5 quarts...when you had it on the jack if you turn one wheel will the other one spin in the opposite direction???
Old Sep 19, 2004 | 01:58 PM
Todder's Avatar
Todder
Could be to much oil in there, check your level.
Also do you do a lot of in town driving? I had a ol 460 when I was in high school and it would puff some smoke every now and then if you didn't get on it to blow it out.
As for the diff, I guess your positive that its a limited slip. Maybe get the rear end serviced at the dealer or at shop with the correct oil and see if that helps. Make sure you check for metal shavings in the old oil though.
Old Sep 19, 2004 | 02:45 PM
wickdgt's Avatar
wickdgt
Both of them spin in the same direction. Yes I do a lot of driving in town. Thanks guys:
Edgar
Old Sep 19, 2004 | 03:33 PM
here is some light reading
https://www.ford-trucks.com/forums/s...d.php?t=284136
Old Sep 19, 2004 | 05:25 PM
wickdgt's Avatar
wickdgt
Thanks for the info, I have LS cause I read the tag and both wheels go foward whne I turn them while on the jack, but I can't make it brake loose by hand, it makes me almost spin with the tire,LOL. I guess I'll have to test it with a bit of water under the tires to see if will spin them like ina burn out. If not, I guess is going to the dealer.
Edgar
Old Sep 20, 2004 | 04:20 PM
Shepard's Avatar
Shepard
Search the v-10 forum for "puff of blue smoke". Lots of posts and threads on this issue.
Edgar
ahuggins6
2004 - 2008 F150
Apr 17, 2013 07:08 AM
7.3 Ex
Feb 8, 2013 11:05 AM
DND58
May 6, 2011 09:58 PM
fordman19762003
2004 - 2008 F150
May 31, 2009 07:00 PM
Mulepick
Jan 1, 2001 07:49 PM
