4x4 not working
Old Sep 19, 2004 | 08:45 AM
danger ranger 29175's Avatar
danger ranger 29175
Question 4x4 not working
My 97 ford ranger isn't working wright when I put it in four-wheel drive. After I lock it in and put it in gear it doesn't work. It acts like it is slipping or not fully locking in. Does anyone know what this might be?
Old Sep 19, 2004 | 06:09 PM
Loan Ranger's Avatar
Loan Ranger
Does your truck have manual lock-in/lock-out hubs or automatic hubs, please?
Is the problem in 4-wheel Low? High? Both?
Old Sep 20, 2004 | 03:09 PM
danger ranger 29175
my hubs
I have automatic hubs on my truck. The problem occurs in both low range and high range.
Old Sep 20, 2004 | 03:13 PM
fordtrucklover94's Avatar
fordtrucklover94
could be something wrong with the actuators, the motor might not be engaging properly since they are automatic, had that problem on a 94 ranger 4x4
Old Sep 20, 2004 | 07:32 PM
wayneo's Avatar
wayneo
Take the cap off the end of the hub for your auto locking actuators,the old style had a big sring in them that held tention on the actuator so all you had to do was enguage from inside vechile, as the maual when you turned the switch on the hub to lock in the spring would push the actuator in a hold tention until unlocked. The newer ones have a funny looking spring in them, anyway if this spring is weak it has lost it's strength and is no longer holding the tention needed for 4x4. Check the spring it will be located just inside the cap that you pull off...Good Luck keep us posted as to what you come up with.
Old Sep 21, 2004 | 05:58 PM
99xlt4.04x4's Avatar
99xlt4.04x4
On my 99 they are vacuum operated. There is a seal in the hub that holds the vacuum. It has probably cracked or dry-rotted or something. But not sure if yours are the same or not.
