1978 - 1996 Big Bronco
egr valve
Old Sep 19, 2004 | 08:14 AM
arch-nemesis's Avatar
arch-nemesis
egr valve
good morning to all
i have a 94 302. its showing through codes that my egr valve has insuff. flow. should i trouble shoot or just get it replaced?
also i noticed on my smog thingy it has red,black green,and beige hoses going around the moter from left to right. on the right side, the last to hoses are cut. found the cut peices in the glove compartment. but no matter how i position them i find no connection to anything. i replaced my cat already. was totally clogged. and my new one already sounds different. dont want to ruin this one.any advice?
Old Sep 19, 2004 | 09:17 AM
Pam's Red's Avatar
Pam's Red
You can take the EGR apart and try to clean it, that should work. Your vacuum lines should be reattached. The diagram is on the valve cover or someplace you can find it. Buy some vac hose that fits tight over the broken ends and try to patch it together that way. Otherwise, run new vac hose.
Pam
There is a pic of a 91 351w vac routing in my gallery, just put your cursor over my name and you will see the options.
propellerhead
1983 - 2012 Ranger & B-Series
Jun 14, 2013 08:14 PM
My Good 'ol 92
Aug 14, 2011 12:10 PM
dawhits1
Jan 9, 2011 07:05 PM
bghnkinf250
Feb 20, 2010 08:05 PM
molinsky
Aug 29, 2007 07:28 PM
